What does the "Save to all" button?
Crrispy
Bug Zapper...
FreeStyler Version: 4.1
Post by Crrispy »
.. in the scene/sequence editor. It's not explained in the online doc.
Thanks.
PS:
Crrispy
"Has mastered fixture creator"
Funny :-) Was much easier to master than FS!
Android Dev (Moderator)
FreeStyler Version: BETA
Re: What does the "Save to all" button?
Post by Mattotone »
The changes you make to a scene ie change a gobo colour will be saved to all scenes in that cue.
values previously set will not be transfered to all scene, only new ones. so if its a new scene, all your values will be duplicated across the cue, but if you go back to say the first scene because you forgot to open a shutter for a fixture, open the shutter click save to all and every scene will now have the shutter open.
