Fixture Contest 930 Topic is solved
Frankiewizard
Fixture Contest 930
Post by Frankiewizard »
Hello every one out there in FreeStyler land I will be using four very little robos in a few weeks time the fixture is not in the fixture library I have tyred to create a fixture library for it but it has not worked ! There are only six channels I thought it would be easy but I am indeed having problems ! HELP ! ! !
Regards Frankie. :roll:
Re: Fixture Contest 930
if your having problems please post a link to the manual and the fixture file (exported version) to the forum then we can check it for you and tell you whats wrong!
Frankiewizard
OK will do cheers ! :fs:
its the best way to learn if we point out whats wrong with the one you tried to make!
