I will file it in the bug report form as soon as it works again, meanwhile:
If using the "Delete" option in the "open scene" dialog box/list, the scene is deleted, but remains in the list until you close/reopen the "open scene" dialog box.
And also, it's not deleted in the cue or the buttons, so afterwards, trying to start it in the cue results in a "file not found" error, which is quite logical.
I think there should be a check if it is used before deleting the scene, asking "Warning, this scene is used in a cue or a button, are you sure you want to delete?". And if "yes", delete it from every reference in FS.
Another small bug - deleting a scene
Crrispy
- Bug Zapper...
- FreeStyler Version: 4.1
- djSupport
Re: Another small bug - deleting a scene
i think the above problem has been around for ages
