Question:
Keyboard shortcuts don't work if the FS window does not have the focus. This is very annoying if using FS together with a DJing program on the same machine (I don't need kb shortcuts for Virtual DJ so I disabled them). Maybe this is a Windows limitation and only CTRL-.. or Alt-.. can be detected if the program window doesn't have the focus? Then it would be fine to allow this kind of shortcut keys,currently I can't choose CTRL-somekey or Alt-somekey.
Once I have programmed everything in the way I like in FS (long is the road.. lol!), I'd just want to use keyboard shortcuts during live use, with VDJ in the foreground (takes up all the space on my 1024x768 laptop..).
Which brings another question: seems that kb shortcuts can't be assigned to cues? Tooo bad since this seems the good way to call back multi-step scenes, pile them etc..
EDIT: just found that "cue" = "sequence" in the keyboard shortcuts menu. Works fine, but naming is a bit confusing
