This is from the old forum
Pilou2003
Can you tell me how install them. Befrore I used fs 2.95d and it worked praperly.I ve did the same procedure to install the the version 2.96 and then easyy view. In FS I can open easyview but i can't control fixture in easyview
Theres a tutorial in the how to section for installing easyview manually, Make sure your easyview is an uptodate version.
kind regards
I can't use easyview with the new version of fs
Jaykie
- FreeStyler Version: 3.01
- Twitter: http://twitter.com/jaykie
