Override buttons numbering
Crrispy
Bug Zapper...
FreeStyler Version: 4.1
Post by Crrispy »
Hello,
Would be nice to see button numbers on the override buttons panel (for example in a darker grey on the buttons themselves), it would be easier to assign keyboard shortcuts, because the keyboard shortcuts menu mentions "Button 1, 2" etc... so currently you have to go back to the buttons panel and count manually...
Re: Override buttons numbering
would be usefull for people with half a brain.... :)
honslow
Post by honslow »
BUT: We are many of those with half a brain out there.... :D
Thought it also may save a few seconds with that feature sometimes when you are in a hurry.
Crrispy
Bug Zapper...
Post by Crrispy »
Half a brain is already a lot for a USER :lol:
djmaq
Post by djmaq »
I'm not shure if I understand right what Crrispy said.
I think he want to have a funktion which show the keyboard shortcuts on the override buttons. Is it right?
If not I think it maybe a good ideas for later versions of freestyler. I could imagine that I write a cue which turn all MH 'red' for example. If I put this cue on a progrmmable 'override button' it woul be nice if the button get a red background and on it there is the letter from the keyboard shortcut.
Very usefull if you have a notebook which you rent togehter with the MH to customers he can start freestyler nd everything is fine. ('programmable overridebutton window' was started via (Freestyler Setup->Preferences->Extra options->open cue and override buttons on startup')
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
yes not a bad idea, could display the button number then when a shortcut is assigned display the shortcut.
Mattotone wrote:yes not a bad idea, could display the button number then when a shortcut is assigned display the shortcut.
havent you guys heard of sticky labels??? they work well too just remember to get easy peel....
Post by Mattotone »
I think after a while id have so many stickys on my screen couldn't see any thing, and what happens if i move the window, id have to re stick. lol :lol:
Return to “Ideas and Remarks”
