2 bugs reported
Crrispy
Bug Zapper...
FreeStyler Version: 4.1
2 bugs reported
Post by Crrispy »
Version 2.96g
The help->about screen does not show the version. I can live with this :-)
When saving a scene and selecting "add to buttons" before saving, the scene is added to the 1st available button, but the scene name does not appear on the button, it still appears empty. And you can not name/rename the button manually, so currently this checkbox seems useless.
Re: 2 bugs reported
the first email you sent is a hotly discussed issue about the version! Raph has not implemented it in that way thats his choosing its on the splash screen tho
Android Dev (Moderator)
FreeStyler Version: BETA
Re: 2 bugs reported
Post by Mattotone »
I think i experienced that bug last night, when trying to create a scene to move my heads onto the venues mirror ball.
However was so busy trying to get the lighting setup to match the venues dimensions forgot all about it.
for the version number i can really see the need for this adding to be honest.
it doesn't really take long to add, but would save so much hassle.
1. Its in keeping with standards.
2. I have many versions of freestyler for bug testing / support for particular versions. And a quick way to check what version im running without having to restart freestyler would be a god send.
So can relate to the frustrations of it not being there.
Kind regards
Matt
Crrispy
Bug Zapper...
Re: 2 bugs reported
Post by Crrispy »
I'm a bit surprised it is a "hotly discussed" topic?! Must take 30 seconds to add this to the "about" window, and it is an absolutely standard feature of any Windoze program. Takes longer to discuss than to add to the code ;)
