Create sequence and overdrive buttons.. Topic is solved
djlorenz
Post by djlorenz »
hi... i want to create some buttons to have flash and sequences ready during my show.. but i'm not able to do it...
i wanna flash 2 RGB pars
i open a new sequence, i select the pars, i select SNAP on channels and set them to 255, then i save the sequence.
i open the buttons, i drag the sequence and set the button with "flash button",
but when i click on a button nothing appears... why?
regards
Lorenzo (from italy)
Re: Create sequence and overdrive buttons..
what fs version are u using??? are you sure that you have set everything correctly???
djlorenz
Post by djlorenz »
version is: 296f
controller: entecc open dmx
the hardware part is set ok (if i'll use the buttons it works) i don't know if the freestyler part is ok... is the first time that i use sequences and buttons... "live" setup is ok...
thankyou
Crrispy
Bug Zapper...
FreeStyler Version: 4.1
Post by Crrispy »
Quite strange, at least this works fine here (apart from the "stop everything moving" problem - see other thread). When you set the channels to 255, the projector lights up fine? You could also upgrade to 2.96g but I don't think it will change much, this is basic operation and should work fine (and I'm a beginner with FS too! :P )
Also remember that the overide buttons only play single sequences thats just 1 scene (a static sequence)
