ENTTEC open DMX and new FS versions fail!
Mike Vaghur
Post by Mike Vaghur »
:x
F...k! I've shit off the event cause FS hadn't saw the Enttec open DMX interface (I wiggled out only with console).
And all the reason was that a new versions (F,G) of FS doesn't work with drivers coming with my interface from ENTTEC.
:idea:
So! If you have a message from FS "Open failed" - Download the new drivers from ENTTEC site!!!
Android Dev (Moderator)
FreeStyler Version: BETA
Re: ENTTEC open DMX and new FS versions fail!
Post by Mattotone »
Allways best to keep drivers uptodate.
I carry on a memory stick, the latest drivers for enttec, freestyler instalaltion, and my backed up show.
Just in case for any problems i may come across.
2stepsteve
Post by 2stepsteve »
Hi
I have just got the enttec open and it is coming up with 'open failed' when i select the interface in freestyler. I have downloaded the latest driver from the enttec site and its still sayin it. I downloaded the d2xx_setup.exe is that all I need to download and install?
I have the open and yes it should be! is it plugged in and installed fine if not run the setup again and see what happens!
Post by Mattotone »
Don't let windows overwrite the driver with its own, the driver windows supplies is no good.
and the 'updDATE' one that can show in windows update if it updates while you have it connected...
DMX DAVE
Post by DMX DAVE »
Oops! For some reason I thought this topic was locked.
I started another thread on it on accident.
The thread I started:
ENTTEC open DMX fail! Thats what I get when I run FS. I have tried running current drivers and no luck. Grrrr! :x
Can someone offer some insight?
For some reason mine just won't work.. I did have it working a few years ago with no problems.
Return to “DMX Interfaces”
