Joystick Topic is solved
Jaykie
Joystick
Post by Jaykie »
This is from the old forum
Rockdraget
Hello.
I Have exact same problem with my joystick as everyone.
I Can´t pan or Tilt my scanners.
Why they dosen´t move????
I think i have done everything right!?
:toggle pan tilt function
:enable Joystick
I can change color and gobos and so on but not move them.
I Have a new USB Logitech joystick
Can somebody help me??
Matt
Its something with USB joysticks. They communicate differently then Game Port Joysticks. With Game Port joysticks, all they did was emulate a keyboard. But usb uses joystick data. I wonder if there is a backwards compatibility program out there..
Tom_the_LD
My USB Joystick allows me to pan tilt (according to the software - not tried live).
Mine is a PCLine and cost about £10.
It has a serial conector on the end (gameport), but came with an adapter to turn to USB. SO technically it is outputting serial - although it uses a USB port. Genious hey? ;)
