FX console with patch.
sparksounds
Post by sparksounds »
I think it would be nice to see a window with all the chases/seq/sound2light etc all on different tabs and then a fader view below. So basically you could select your effect - by clicking and selecting effect parameters and then click an empty fx box above the fader to sort of patch effects in.
This could mean that I could select all eg. dimmers on various different types of light and have them in a chase etc.
If anyone has seen/used sunlite that is what i'm trying to describe.
also pre made effects - movements chases etc would be good! - so you could just busk the lighting live if needed!
effects:
X fader/wave
sound to light
Chaser
Sequence - various different seq over a different number of channels.
Phil
Return to “Ideas and Remarks”
