hi guys,
is there a fixture for a switch pack?, do i have to make one?, i have made some dimmers with no problems, can i use a dimmerprofile or will there be a problem with the switchpack needing signals only for off (0) or on (255) rather than a intensity style signal where it rises from 0 to 255.
regards
matt.
switch pack
- DJ
- FreeStyler Version: 3.3.1
- LJ_krede.dk
- FreeStyler Version: 3.3.7
Re: switch pack
you cant make a fixture with on and off values for each channel. however you could use parcans fixture with the shutter configured
I'm almost sure switchpacks has a trigger DMX value (127/50%) where it will switch on (over 127) and off (below 127), so don't you worry about using a dimmer/parcan fixture, or if you fade the values in FreeStyler. if you want to you can make macros for on and off values. when you are programming a sequence i would recommend you use the "snap" function in stead of "fade" for your switchpacks. then you are sure when the on/off change happens
/LJ_krede.dk
Aalborg, Denmark
Aalborg, Denmark
- DJ
Re: switch pack
thanks,
its pretty much what i thought, ill have a play, thats twice you have helped me now.
regards
matt.
regards
matt.
Re: switch pack
Read the Par Can, Dimmer, Switch Pack tutorial for the Fixture Creator in the FreeStyler Wiki.
- DJ
Re: switch pack
cheers 4 thatOnge wrote:Read the Par Can, Dimmer, Switch Pack tutorial for the Fixture Creator in the FreeStyler Wiki.
Re: switch pack
Your welcome, I hope my tutorial helps in some way.matt-the-dj wrote:cheers 4 thatOnge wrote:Read the Par Can, Dimmer, Switch Pack tutorial for the Fixture Creator in the FreeStyler Wiki.
- DJ
Re: switch pack
i had a look, all done,
many thanks.
many thanks.
