took me all day to found out the following:
if you want to use the freestyler preset with ALL buttons (incl edit, exit, preset etc)
notice presets are standard opened (and sent to the BCx) as preset 0
this preset gets lost when you reset your BCx
when you copy/paste the .syx to preset 1 it remains saved!
even after resetting the device!
BCEdit - Can't upload presets
- cyberb0b
- Commited FS Forum helper
- FreeStyler Version: Beta
Re: BCEdit - Can't upload presets
export in bcedit the .syx file and send it with midiox to the bcf..
