9.6G and groups
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
9.6G and groups
Can anyone confirm, that the blackout and release override groups are no longer working using MIDI?
Iv tested E & F and blackout works fine. Can some one please confirm this.
Edit: Release was due to a bad config setting, on my behalf. Dope. Still no luck with blackout.
- cantyco
- FreeStyler Version: 2.96h
Re: 9.6G and groups
are you meaning a group blackout or just blackout for everything, blackout for everything is working fine,
i can test stuff when i can in at 5pm if you want..
- Mattotone
Re: 9.6G and groups
group blackouts, just can't get them to work.
- cantyco
Re: 9.6G and groups
havent tryed the group blackouts so i will try them as soon as i get in for you.
- cantyco
Re: 9.6G and groups
Sorry,
was unable to get onto the forums so couldnt reply.
But i tryed the blackout groups with the behringer and it seemed to work ok for me, could it be the way its setup or something?
- Mattotone
Re: 9.6G and groups
I think it could be my groups. il do a reinstall if not il contact Raph.
Cheers m8
Cheers m8
- Mattotone
Re: 9.6G and groups
After reinstall now works fine, odd??
- cantyco
Re: 9.6G and groups
yeah sounds a little odd...
- LJ
- FreeStyler Version: x2
Re: 9.6G and groups
Hello
I have 3 groupe
groupe 1 = 4 MH
groupe 2 = 2 moonlight
groupe 3 = strobo
black out groupe 1 works fine, but when i black out groupe 2 then MH 2 from group 1 open the chutter and MH 1,3 and 4 not.
I use the bcf 2000
Daan
I have 3 groupe
groupe 1 = 4 MH
groupe 3 = strobo
I use the bcf 2000
Daan
Windows 7 Ultimate, HP Pavilion dv9700 Notebook, Intel Core 2 Duo 2.1 Ghz, 3 Gb RAM, GeForce 8600M GS 512 Mb
Enttec Pro DMX Interface
Berhinger BCF 2000
Android phone Sony Ericsson expira x10, Android 2.1
Berhinger BCF 2000
Re: 9.6G and groups
Having the same problem i am wondering if you found any solution?
- Mattotone
Re: 9.6G and groups
my group 3 will noy blackout, nore will channels 3 & 4 of fixtures in that group release from overide
