startup problems Topic is solved
wesley2004
startup problems
Post by wesley2004 »
I'm a new user of FS and i already love it!
Easy to work with and many things possible; GREAT!
I recieved my DMX4All interface last weekend.
When i put it in the usb and i startup FS the program hangs and has to be closed.
If i startup without the usb in it it startup and works after plug in the usb later.
Is that normal way to do?
dmxlighting
FreeStyler Version: beta
Re: startup problems
Post by dmxlighting »
Im not familiar with the dmx4all interface but Id say that it should work on startup WITH the device connected.
However if the only way to get it to work for you is to start up THEN connect, then carry on this way. No harm will be done.
I don not think there is a cure for this it may just be how it is for your device.
