Hi guys,
I wuold like to knows what's changed in 3.31 version.
Many thanks
Alessandro
New version
a_faggioli
Re: New version
I had already read the wiki page but I would like know what's changed exactly so to understand if I need to update my installation, because last time I reinstalled FS I had some problems with 3D Viewer and I want do it only if I really need it.
Bye
Ale
Bye
Ale
Re: New version
Well, I dont know more than what the wiki page says: small fixes + resolution fixes.
I dont know what version you are running but you should check all the changes for the version in between your version and the latest. I always recommend people to update to the latest version because it should be better and more stable. However I know there is exceptions, but I have never experiencede that with FS. It has only got better for each update (my opinion of course)
MarSafe
Re: New version
I have to agree with Alessandro: Releasenotes are shown AFTER installation of the new version.
Is it possible to post the releasenotes in the WIKI so we can check them before we install?
Grtx,
Martin.
Grtx,
Martin.
Onge
Re: New version
Problems with the 3D Visualiser is nothing to do with FreeStyler.a_faggioli wrote:I had already read the wiki page but I would like know what's changed exactly so to understand if I need to update my installation, because last time I reinstalled FS I had some problems with 3D Viewer and I want do it only if I really need it.
Bye
Ale
It should always be installed when updating FreeStyler.
Always allow it to install the "Suidi" drivers. Always allow it to finish installing before continuing with the FreeStyler install.
There will be two setup programs running, 1st the FreeStyler install and then the Magic 3D Easy View download and install. The Magic 3D Easy View install window should cover over the FreeStyler install window until it has finished, then and only then continue with the FreeStyler install.
I have never had a problem installing it or getting it to work, on either XP or Vista, cannot comment on Windows 7.
- dmxlighting
- FreeStyler Version: beta
Re: New version
We try to put the info on the wiki when an update or new release is avalible.MarSafe wrote:I have to agree with Alessandro: Releasenotes are shown AFTER installation of the new version.
Grtx,
Martin.
Someone HAS done this already. I know it does not tell you much but that would be ALL the info WE have.
It would appear that this IS NOT a major release and is mostly a 'fixed' version of FS which will have little bug fixes that have been highlighted by FS forum users.
Im a hardcore FS fan and a beta tester and as such I always update / upgrade to the latest release.
If the version you are currently on works well for you and are happy with it then you may not want to upgrade if you feel it will possibly cause problems.
It most likely wont cause any problems but ALWAYS back up your work before any upgrade is performed.
