1 button doesnt work
cantyco
FreeStyler Version: 2.96h
Post by cantyco »
I have a question for all you bcf200 owners, i have been resetting mine up today to get everything exactly how i want it for my latest gigs and stuff and have noticed that one of my buttons on it doesnt work,
on the bottom right there is a set of four buttons, the top left of it does not work, and i can't assign it to anything, has anybody else got the same problem, or could this be a problem with my actual behringer.
I didnt know if it could be a problem with the sys but its set up from the one on the freestyler website.?
Android Dev (Moderator)
FreeStyler Version: BETA
Re: 1 button doesnt work
Post by Mattotone »
Button one works fine for me, I don't use the suggested profile i created my own.
have you checked the settings on the behringer unit, to make sure that channel is sending midi data?
cantyco
Post by cantyco »
could you talk me throught the steps to do this?
when i hold down edit and click on the button it doesnt do anything, where as if i do that for any of the other channels it does.
i have a feel its the unit, it was second hand when i got it so recon thats the problem.
Post by Mattotone »
Yeah sounds to me like you have a doggy button, Pressing edit and selecting the button should make it glow red, regardless of its current midi state.
cantyco
Post by cantyco »
yeah its a doggy button cuase i faffed with the button and it occasonaly lights red.
I may take it all apart one day and see if i can repace the button on the circuit board...
thanks for your help anyway.
Return to “BCF2000”
