hi i am looking for fixture files for the following:
robe dj scan 150xt
robe djroller 150xt
laser uk
please can somebody help (:
request for robe files Topic is solved
Mavi
Re: request for robe files
I do not have this fixtures and therfore not the fixture files. But I want to encourage you to try building the fixture files on your own. Here you can finde a how-to: http://www.freestylersupport.com/wiki/f ... oving_head
However, you need to have the manual (or have to know anyway) with channel discriptions. First to try on your own, then for attaching it to a post and let us have a look at it during troubleshooting
marcdjwilliams
thanks for your reply . i have done the files for the dj scans and dj roller and they work fine but am really struggling with the laser ? do i need to set them all up as makros ??
Onge
Depends on the channels and their values, you can make use of gobo and colour wheels to select patterns etc or you can use macros.marcdjwilliams wrote:thanks for your reply . i have done the files for the dj scans and dj roller and they work fine but am really struggling with the laser ? do i need to set them all up as makros ??
Have a look at some of the other laser fixture files to see how they have been done.
Shannon D
I used macros for my laser. I set up all the proper channels, just like any other light, but found the macros way more useful. I went thru all the auto shapes/programs, found the ones I really liked and wrote down to channel values. From there, created the macros to match.
