Hello all and thank you for reading my request. First off I am not a lighting guy, just and sound guy who gets pushed into programming this show once a year. I also wont have access to these these fixtures until the day I have to program them so I don't have the option of learning by trial and error (my usual technique).
I also need a profile for a Highend Studiospot 575. I could most likely figure this one out by looking at other fixtures but if someone already has one it would help tremendously.
I have attempted to create a profile for the 120RZ but I don't know what some of the terms are. I'm attaching the partial profile I started and the data sheet. If anyone could look at the profile I built and fill in what ever else may be needed I would greatly appreciate it. Thank You.
Request Elation RGB 120RZ Impression Topic is solved
specter333
impression_120rz_dmx.pdf- (1.16 MiB) Downloaded 71 times
specter333
Re: Request Elation RGB 120RZ Impression
Tried to upload the wrong file. Here is the correct one.
RGB 120 RX Impression.pff- (452 Bytes) Downloaded 59 times
specter333
I believe they will be in normal mode. Thank you very much for creating this. I won't be able to test it until Monday but it looks like it should work well. Thanks again.
