Equinox Triclops Topic is solved
brandy
Equinox Triclops
Post by brandy »
Hi I am new to freestyler and dmx but getting there, i HAVE A 3 head light called Equinox Triclops and want to use it on freestyler and magic 3d visualiser
but dont have a clue how to make up the fixture I have tried so many times but cant get it to move each tilt on their own Please Please can someone help cheers Brandy.
Re: Equinox Triclops
Post by LJ_krede.dk »
can you upload the fixture file and tha manual for the light. then we can see whats wrong?
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
brandy wrote:Hi I am new to freestyler and dmx but getting there, i HAVE A 3 head light called Equinox Triclops and want to use it on freestyler and magic 3d visualiser
Please upload a user manual or post a link to one if you can.
I guessing that this fixture is not a 'normal' type like a scan or a moving head. Therefor it will be a little trickier to mae a profile and may not be ossible at all to make a 3d profile.
Onge
Post by Onge »
OK,
This is going to be an extremely hard fixture to create in Scanlibrary for use in Magic 3D.
The main problems I see are as follows :-
1) The fixture has 3 tilt channels, you can only have 1 in a Scanlibrary fixture. So you need to create 3 fixtures.
2) As there is only one light source per fixture, which is OK as we are going to create 3 !!!!
So what you need to do is create three 9 channel fixtures, each with it's own tilt, pattern blackout channels and 1 of the fixtures to have the other defined channels and the others can just have blank channels for the rest. Once you have all 3 created then you need to patch them to the same address. Drag and drop them on the same address, you will get a "cross hatch" image warning you that you have multiple fixtures at the same address but should be OK.
Hopefully that will work and I hope that helps,
Onge
Post by Onge »
I have created shells of the 3 fixtures to get you started. Put them in the FreeStyler\Scanlibrary folder.
Open with Scanlibrary to edit.
Patch each fixture at the same address in 3D Magic Easy view, drag and drop them. A crosshatch will appear but it is OK. Arrange the fixtures to look like the real fixture ?!?!?!?
You will need to define the patterns on the gobo channel on all 3 fixtures, I have put in the "Blackout" (shutter closed).
You will also see the text in the channels that tell you to use one of the other fixtures.
Remember
Hope it helps,
Equinox Triclops 1.ssl
Equinox Triclops Fixture 1
(596 Bytes) Downloaded 81 times
Equinox Triclops 2.ssl[/attachment ][attachment=0]Equinox Triclops 3.ssl
Equinox Triclops Fixture 3
(575 Bytes) Downloaded 74 times
Equinox Triclops Fixture 2
(575 Bytes) Downloaded 70 times
brandy
Post by brandy »
hi Thanks for all your help didnt think DMX was as conplicated i have down loaded some details of the light and i will try and get my head around the 3 fixture make up thanks everyone hope i can sort this cheers brandy.
Scan.pdf
(1.1 MiB) Downloaded 69 times
Onge
Post by Onge »
brandy wrote:hi Thanks for all your help didnt think DMX was as conplicated i have down loaded some details of the light and i will try and get my head around the 3 fixture make up thanks everyone hope i can sort this cheers brandy.
Not a problem, take a look at the DMX Wiki it will help clear up some things. Honestly DMX is actually not that complicated. How it's used in programs etc. is where it can get complicated.
The FreeStyler Wiki is also another good place to get to grips with FreeStyler. People are adding more and more to it. It is by no means complete but with that and the built in help in FreeStyler you should get a good idea on how FreeStyler works. Read dmxlighting's tutorial on submasters it is a very good way to control your show(s).
Remember those fixtures are only for Magic 3D you cannot load them into FreeStyler.
I found a copy of the manual on the Prolight UK website, which is how I got info to create what I did but it does not go into enough detail about the patterns channel(s), just tells you there are 15 patterns. As I do not have the fixture I cannot control it to find at what dmx value the pattern changes, you will need to do that.
brandy
Post by brandy »
Thanks so much for your help that has given me something to go at now just tried what you said and now i need to make changes in freestyler now cheers ............
brandy
Post by brandy »
Hi cant seem to get the hang of this dmx ficture making or is it because i dont have enough info on light i dont know how you guys do it I find it easier fitting kitchens and bathrooms it must be a mid life crisis ha. If anyone gets one of these light (Equinox Triclops) and makes up the fixtures for freestyler and magic 3d please let me know I will keep trying ...............................cheers
upload the exported fixture file, and tell us what the problem is,, then we will help you.
brandy
Post by brandy »
Hi the only info i have is in the attachment I have had great advise from you guys like making up 3 fictures as 1 and patching them together in the magic programme I do get some movement but not experienced enough to make both programmes talk to each other dont be hard on me i am trying i have sent a e-mail to manufacturer for more info but not received anything yet Cheers Darren
Scan.pdf
mr_creature
Post by mr_creature »
Hi as a newbie myself and have this light - was wondering if anyone has done it for freestyler ?
I cant seem to get to grips with magis program at the moment - but am slowely getting to grips with freestyler :)
frajola
Post by frajola »
Hi, I´m new to Freestyler and cannot get the fixture for Equinox Triclops and Equinox Eyebar, can anyone help me, thanks.
http://www.djstore.com/manuals/pro/proeqled50.pdf
https://www.proaudiocentre.com/docs/EQLED39-um0.pdf
