Hello
Is it poosible to make the fixture of the Quadro beam
You can find the manual on the beglec.com website
JB Systems : Quadro beam Topic is solved
Re: JB Systems : Quadro beam
@ Jellos. Next time you ask for a fixture file please upload the pdf (if it is less than 2 MB) or give a link (not beglec website) where people can download the manual. it is really difficult to download the manual from beglec website.
@ Jellos and Oriambre : I really think you guys should try to make your own fixture file for this fixture. It is only 1 or 6 channels and really simple, there's really not much into it.
I can make the file in less than 5 minutes, because you only have one channel you have to type values for.
give it a try and we will help you if you have problems. there is some tutorials on FreeStyler Wiki
