This is from the old forum
Frankiewizard
Is there a manual or a start up guide ! yes I am indeed new to all of this lighting controled by computers.
read through the tutorials and how too's
This is a good guide i found to help you create your first show.
http://www.freestylerguide.com/
Bobko
Hi I'm new to FreeStyler and DMX lights i have 6 Chauvet intimidator 1.0s and 2 American DJ mighty scans. i built the open dmx controller using this break out board http://www.sparkfun.com/commerce/produc ... cts_id=718 and a MAX481CPA+ sample from maxim-ic.com. i'm running 2.96e on a brand new laptop.
i have gone through this guide and have created lots of sequences and saved them to disk. now how do i load them into the cue? how do a load them into the override buttons? does the cue just play my sequences in order? can the cue be trigered by sound? the guide got me through the basics and left me hanging. i want to know more about the advanced stuff.
Bob
cerebro
I have the same question in a couple of posts. The manual does not talk about the cues, could someone please clear up the cues for us? I know I am a newbie, but would just love someone to give me a quick crash course.
Replies appreciated..
Is there a manual with FreeStyler Topic is solved
metron9
Re: Is there a manual with FreeStyler
Same here. I just finished programming my own DMX receiver for an 8 channel PWM LED device. I have fast cue switcher on the screen but it may as well be a picture in a pdf file because I can't make it do anything at all. Insert sequence opens the offline sequence editor when I double click a scene I have saved but thats all id does. I can program microprocessors in assembly code but I can't figure out how to make use of this program.
What do all the buttons do?
Why does the fader control on the upper right of the screen always close when I switch between fixtures?
Why when I select two fixtures doesn't the fader control show all the DMX channels (with numbers) so I can use the faders for all devices selected?
What version is the software I am running the usual HELP ABOUT shows no version?
I am an old programmer from way back in the dark ages and I know documentation is very hard to do but if the program is not somewhat intuitive a list of functions and commands and what they do would be of great help.
metron9
Arrrgg, I did read the help file and I see now you drag and drop a scend in the cue. Ok I see how it works now but after running the vue, I try and make another scene and non of the steps save any of the fadr controls so it's broken...
- djSupport
just quickly you version is determined by the file you downloaded if you downloaded it off the site you would know what version your using!! The version iis also on the splash screen as you boot freestyler.
rlelek
Hey,Jaykie wrote:This is from the old forum
Frankiewizard
Bobko
Bob
cerebro
I apologize for leaving you hanging. As stated on the website, this is all done in my spare time. Recently my Hard drive failed , the same one with the guide on it. I was able to recover the guide yesterday night. In addition to this delay, I have been doing a bunch of work on my Mobile DJ business, and that has eaten most of my extra time that summer PE class (6 weeks) left behind.
I'll be sure to finish this guide for all of you soon.
Thanks for reading
