cloning and addressing by groups Topic is solved
mikeb
Post by mikeb »
I'm trying to use the clone option to link similar fixtures togther, but it doesn't seem to do anything. I'd like to be able to set them so that when I change the intensity, colour etc on one fixture, the cloned ones change as well.
Alternatively, can I address the fixtures together by their group? I know I can select multiple fixtures from the group window, but can I tie their intensity channels together somehow? Same with a Midi input, can I tie multiple fixtures to a single midi address?
Re: cloning and addressing by groups
Post by LJ_krede.dk »
the clone feature works! I have just tested it on the newest release.. be aware that it only works when playing back sequences from the cue window and submasters. not when you try to control the fixtures manually. This is also described in the help content in Freestyler.
Extract from the help content in Freestyler wrote: Clone fixture:
Copy the playback output from one fixture to another
