Problem strobe MacMah S1500D Topic is solved
LJ sunlight
Post by LJ sunlight »
Hi to all!
I have a little problem with my new strobe is a MacMah S1500D.
It is very good, but the only problem is that I can not have control via DMX by FS. I try to create a fixture, but nothing changes, my strobe remains silent to my call.
If someone had an idea where the problem comes ...
I joined my record and file. Pff
Thank you in advance! ;)
PS: If I could have answered quickly, his would simpa because I have a party tomorrow and I wanted to test it by DMX! Anyway if this is not the case, do not worry! ;)
Strob S1500D.pff
(3.79 KiB) Downloaded 71 times
Re: Problem strobe MacMah S1500D
Post by LJ_krede.dk »
the fixture looks alright.. however the shutter channel is named Gobo1. this shouldn't effect the functions thou.
you have to make sure you have set the addresses correctly in Freestyler and on the strobe. try to set the address to 1, set dip switch 1 on the fixture to on, and set the rest to off. also set the address to 1 in freestyler. now it should work.
if not, can you control other of your lamps with Freestyler?
LJ sunlight
Thank you, I finally get a handle, a little, the signal ...
I explain, I did what you said, put the strobe has the address 1 and delete the channel Gobo1. At that time still nothing ... I test something else and give all the dip switch on and off the strobe that sets out by DMX ... weird ... all my dip switch is on off and works ...
One problem to resolve but another appears, I do not manage the intensity of light and yet the improvement ... I can not put that light at max or mini!
Can also adjust the speed of flash.
How can I fix this??
Is my fixture in Fixture créator was well set at "strobe" and "intensity channel??
PS: Sorry if my English, not terrible, but I'm French! ;)
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
A couple of things...
First you could probably use a showtec Jumbo Strobe profile - this is already in the list. I use it with my very similar strobe and it all works just fine.
Secondly - if your strobe is anything like mine - dont use it above channel 200 as it may not work - This is true of my strobe.
Onge
Post by Onge »
You could also use the Stairville Strobe 1500 DMX fixture.
As dmxlighting said, ensure that you have dipswitch 1 on and the rest off. Patch the fixture to address 1 in FreeStyler.
Select the fixture, move fader 2 (Intensity) to full on. Then move slider 1 to adjust speed of flash rate, can use gobo wheel 1 if you patched the above fixture or use the strobe control.
Remember dipswitches might not be "up" for "on" and "down" for "off". Some dispswitches have "on" marked others might just have a "1" meaning on.
Hanternoz
Post by Hanternoz »
Also make sure that you power off/power on after changing DMX address. It sometimes may be required by the hardware which is not able to read the switches while running (only at startup)
LJ sunlight
Merci pour les réponses et désolé de répondre si tard!!! ;)
Pour le strobe, J'arrive a régler l'intensité lumineuse sur quelques points. Je ne peux pas gérer la lumière progressivement avec la vitesse. C'est soit lumière très forte, avec vitesse semi rapide, soit lumière très faible, avec vitesse lente...
En plus, la vitesse du strobe ne peut atteindre son maximum.
Pourquoi ça ne fonctionne toujours pas. Un strobe ça doit être la chose la plus simple a configurer, je pense normalement. :roll:
dmxlighting
LJ sunlight wrote:Merci pour les réponses et désolé de répondre si tard!!! ;)
Un flash est normalement très facile à configurer comme il l'a normalement que deux canaux.
La vitesse et l'intensité.
Je me demande s'il ya un problème avec votre flash. Connaissez-vous quelqu'un qui peut tester le flash avec DMX? C'est une bonne idée de faire cela si vous le pouvez.
S'il vous plaît laissez-moi connaître le résultat de l'essai.
Lee
Désolé pour mon mauvais français - je suis anglais!
Hanternoz
Post by Hanternoz »
LJ, tu es d'où ? Je suis sur Nantes, si je peux te filer un coup de main....
FreeStyler Version: N/A
Post by remco_k »
I just lost you all... :mrgreen:
Onge
Post by Onge »
remco_k wrote:I just lost you all... :mrgreen:
We are all still here ... Your just not looking in the right places.
Tell me this, when you loose something, you search high and low for it and where do you find it ? The last place you look, so why not look there first ? :roll: :lol: :roll: :lol:
Post by remco_k »
Onge wrote: ...Tell me this, when you loose something, ....
I ask my wife. She has all the answers. :lol:
LJ sunlight
Hanternoz wrote: LJ, tu es d'où ? Je suis sur Nantes, si je peux te filer un coup de main....
Bin, je suis pas bien loin je suis a Cholet!!! :D
dmxlighting wrote:Désolé pour mon mauvais français - je suis anglais!
Pas grave, j'avais oublié de traduire!!! ;)
dmxlighting
Onge wrote: Tell me this, when you loose something, you search high and low for it and where do you find it ? The last place you look, so why not look there first ? :roll: :lol: :roll: :lol:
Cause this would still be the last place too - You can't win!
remco_k wrote: I ask my wife. She has all the answers. :lol:
Hmm yours too ? Mine is like that :lol: :lol: :lol: :lol:
Hanternoz
Post by Hanternoz »
So if you would like some support, feel free to ask and we will organize ourselves
I have mine wroking OK with Freestyler. We will then be able to make cross tests.
Staying at your disposal
LJ sunlight
Hanternoz wrote: So if you would like some support, feel free to ask and we will organize ourselves
Sans problème, sa serait cool, tu pourrait m'apprendre des truc sur freestyler!!! ;)
Si tu veux je te donne mon adresse MSN... ;)
