Hi,i am new here on forum,and new freestyler user to.I need two fixtures
1:http://www.bekafun.net/files/producten/ ... manual.pdf Showtec.
2:http://www.smokemachines.net/data/lemai ... Manual.pdf La Maitre Mvs Hazer
Showtec led wash rgb and La Maitre Hazer fixture wanted Topic is solved
Onge
Re: Showtec led wash rgb and La Maitre Hazer fixture wanted
Both of those are really easy fixtures to create, have a read of the tutorials on the FreeStyler Wiki.
You will most probably find a 4 channel RGB fixture in the list somewhere that does exactly what you want it to do, just need to look through them all to find one. I would not both and just create it.
The hazer you need to decide if you are going to use 1, 2, 3 or 4 channels of DMX to control it.
I am in a good mood so have created both fixtures for you. 10 minutes work.
The hazer is four channel, how you control channels 3 and 4 would be via the sliders on the right. No picture done.
If you want a 2 channel version of this then just change the number of channels in the fixture and do a Save As.
The LED wash done but with wrong picture. macro to turn on units sound activated, but then you need to use the dimmer to turn it off. Not a problem. You could create a macro to zero channel 1 if you wanted.
EDIT: Just edited the Wash to include the Shutter values of 0 and 189 (same as min max dimmer values) so it works with blackout as well.
- dmxlighting
- FreeStyler Version: beta
You are a very lucky lightjock!sulee wrote:tnx
Its always better to learn how to do this yourself so please make the effort to look at how it works. There are tutorials which talk you through the whole process.
