Widescreen touch screen skin?
synkro
Twitter: twitter.com/synkrox
Post by synkro »
Hi everyone just giving freestyler a try at the moment, we have a lightfactory license at our place but when they cant be bothered to give it a decent UI I cant be bothered to learn it..... ;-)
Anyway I'm using an acer 23" Z5600 multi-touch PC to run it, but the touch screen skin falls off the bottom of the screen. Is there another skin I could use, not necessarily native, but that would fit the 1,920 x 1080 resolution of the screen?
Cheers
Chris
Onge
Re: Widescreen touch screen skin?
Post by Onge »
Which touchscreen skin ?
Do you mean Touchscreen 1 ? The one that is already defined.
Yep I get this on my 1440x900 Touchscreen, if I change the resolution to 1280x1024 (don't ask, it confuses me :? ) then it fits but the KeyPad is slightly off screen to the right but I can see and use all the button.
I use Touchscreen 2, takes a bit of work to get it setup but at least nothing off screen.
I am not sure what the answer is. Maybe it needs reporting to Raph.
synkro
Post by synkro »
I didnt realise there were different ones.... Yeah touchscreen one though.
Ah-Ha - didnt realise there was an option for 2nd layout! nice one.
can you backup/restore the config? if so any chance I could see yours as a start point please?
Chris
Onge
Post by Onge »
synkro wrote:I didnt realise there were different ones.... Yeah touchscreen one though.
Chris
Well you could but all I did was throw a lot of the buttons and encoders onto the screen and coloured them up, no proper layout as was only testing.
I need to create a grid as a background so I can line things up properly.
Have a look at this post to see what can be done http://www.freestylersupport.com/fsforu ... =38&t=1702
