Bug with the 3.2.8 Topic is solved
apprenti bidouille
Bug with the 3.2.8
Post by apprenti bidouille »
Hello everyone !
I have a problem with the 3.2.8 version.
I used the patch to update my previous version. It worked well, freestyler opens and loads my programs... BUT : the "outputs" window is always full of "0" even when i load different programs or when i modify DMX values by hand... And of course Easyview sees nothing at all...
I can't test with my enttec interface since i don't have it with me... But i don't know how to recover a working Freestyler.
Of course I've tried to uninstall and reinstall a few times... No change...
At least, where can I download older versions ?
Thanks in advance if anyone can help me ?
Edouard
dmxlighting
FreeStyler Version: beta
Re: Bug with the 3.2.8
Post by dmxlighting »
Were you upgrading from version 3 onwards on before version 3?
apprenti bidouille
from version 3.x.x (don't remember exactly :-P Sorry... ) But the problem still exists on a totally new install...
Onge
Post by Onge »
If you have an interface selected and it is not connected then they outputs do stay at zero. Well that is how it works for me using the Enttec Pro. Obviously no output to Easy View either.
If I select the Virtual Interface then all is good or if I connect my Enttec Pro and re-start FreeStyler all is good.
apprenti bidouille
OMG.. THANKS FOR THAT !!!
I never had to do this on previous versions of Freestyler, so i never suspected this..
Thanks again ! You save my life !
Onge
Post by Onge »
apprenti bidouille wrote:OMG.. THANKS FOR THAT !!!
No problem and I noticed according to your profile you are running a very special version of FreeStyler 6.2.1 ... hee hee hee
apprenti bidouille
:mrgreen: :mrgreen: :mrgreen:
!! N00B spotted !! :oops:
