Hi all, I'm new to this forum. I would like to know if anibody has succeed in having a DMX510-USB adaptor running under winds 7 pro 64bits.
I had follow the hints to have it working under Vista, but it looks like this is not working for 7 unfortunatelly.
Can anyone help me ?
I sent a request to Monacor, but do not have any answer for now.
Thanks in advance.
Laurent
[FIXED]Monacor DMX510-USB and windows 7 64 bits
- FreeStyler Version: 3.3.1
- dmxlighting
- FreeStyler Version: beta
Re: Monacor DMX510-USB and windows 7 64 bits
I have my Enttec Pro Device working faultlessly under Win7 32bit. Can see why it wont work. Have you tried running the driver in compatability mode or am I talking rubbish ?
Thanks for your answer. I tried to follow the VISTA tutorial, which explains things in a clear way. But they do not refer to 64 bits.dmxlighting wrote:I have my Enttec Pro Device working faultlessly under Win7 32bit. Can see why it wont work. Have you tried running the driver in compatability mode or am I talking rubbish ?
I post here the txt file that comes with the driver:
Code: Select all
Settings for DMX-510USB und Windows Vista
The programs DMX-510USB is now working properly under Microsoft Windows Vista. But some settings have been changed:
1. Before installing the DMX-510USB software the driver signature check (system integrity checks) under Windows Vista has to be deactivated:
- one click with the mouse button on the Windows symbol will open the Start Menu from Windows.
- Type 'CMD' in the search bar
- Press SHIFT + CTRL + ENTER at the same time
- Type 'Bcdedit.exe /set nointegritychecks ON' in the command editor window and press ENTER.
- Close the command editor
- Install DMX-510USB software
To reactivate the integrity check type:
'Bcdedit.exe /set nointegritychecks OFF' in the command editor
2. For the DMX-510USB software the compatibility mode for Windows XP has to be set:
- Change into the DMX510USB installation directory
- select DMX510USB.EXE with the Right mouse button
- select Properties -> compatibility
- select 'Start program in compatibility mode for : Windows XP(SP2)'
- select the option 'run program as an administrator'
- press Ok
- start the program with a double click on DMX510usb.EXE
3. To avoid very slow data transfer via USB (for DMX-510USB) it is necessary to deactivate the option "Allow the computer to turn off this device to save power."
-1 Click on "Start" and then right-click on "My Computer."
-2 Click on "Properties" and then on the "Hardware" tab.
-3 Half-way down on the right, click on "Device Manager."
-4 Click the "plus" sign in front of "Other devices."
-5 Double-Click on "DMX-510USB".
-6 Click on the "Power Management" tab.
-7 Uncheck the box that says "Allow the computer to turn off this device to save power."
-8 Click "OK"
if necessary:
-9 Click the "plus" sign in front of "Universal Serial Bus Controllers."
-10 Double-Click on the first "USB Root Hub".
-11 Click on the "Power Management" tab.
-12 Uncheck the box that says "Allow the computer to turn off this device to save power."
-13 Click "OK"
if necessary, repeat point 9-13 with the second "USB Root Hub".
I think that I found my answer thanks to google...
If a component hasn't a 64bits driver, I won't then be able to have it working under 64bits windows.
I now have to wait for Monacor to provide me with such a driver,or I will have to move to a new hardware
Anyway, thanks to you guys for your comments.
In order to help other users that might faced the same problem, see this topic, where the driver has been posted:
http://www.freestylersupport.com/fsforu ... f=6&t=2060
Everything is running well now
