Configuring two programs on the same PC?? Topic is solved
b808
Post by b808 »
Hey Guys,
I would like to have Freestyler be my visualizer and MagicQ PC be my control software.
How can I make these to programs talk to each other on the same PC?
I tried using the Loopback adapter but unfortunatley I am not so versed in this area
so before I mess things up I figured I'd try asking you guys. :)
Thanks a bunch!
Bryan
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Configuring two programs on the same PC??
Post by Mattotone »
I dont currently think its possible. freestyler has no current method of DMX in. small lie there is one interface that does but i cant remember which one it is,
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
Freestyler is not the visulizer. Its Sunlite Magic 3D Easy View that does that. Its lucky for us that FS works with it and also I belive will work with other software too. Have a look at this site http://www.nicolaudie.com/home.php it may have the answers as to if you can use it with magicQ. If not why not have a closer look at FS as your control program. :fs:
