Cant play scene. Topic is solved
leeqwst
Cant play scene.
Post by leeqwst »
I can individualy control all my lights and all scanners move. When I save a 1 step scene and bring it up in the cue page and hit play, it doesnt do anything. I have reset and rebooted my PC and still nothing. Though it was a problem with the addressing on my dip swithces. Every thing looked good except one strobe was set different than what Freestyler was telling me. So I fixed the address on that strobe. Strobe works great now. But after that every thing fell apart....Now I can not see the scenes I have been saving to the cue list. All my old Scenes/cues seem to work fine in the SM's. Why wont my new scenes run in the Cue window. Also I am getting the ! triangle on some of my PARS. Is this symbol a addressing error?
Re: Cant play scene.
Post by LJ_krede.dk »
the triangle means that you have changes the pars manually while running a sequence. manual changes overrides running sequences. press the triangle button in the tool bar and see if this solve your issue
FreeStyler Version: N/A
Post by remco_k »
The triangle tells you this: Overrides are active.
Meaning that whatever you run (like cues or whatever), are overridden by a value that is set by you.
LJ_Krede said it: To release the overrides press the triangle button in the toolbar. The overrides are released and cues should play visible now.
