Cuelist and sunmasters annoyed!!! Topic is solved
aquas
Post by aquas »
Hey ppl,
A lot of time out of the forum... hehe since 3.2.1 i'm having a problem between cuelist buttons and the submasters! they are annoyed with each other, so when i open the submasters the dmx output simply go to 0(with a cuelist button activated), if i close the submasters they go to the right value.
I think this was discusted some time ago, but i check lots of pages and i can´t find it. help please
PS: Next month i will put some pics with a Truck Stage... Freestyler working...
Cumpr
Re: Cuelist and sunmasters annoyed!!!
Post by LJ_krede.dk »
i'm not sure i'm getting this?
are you trying to activate seqences in the cue window AND using the submasters at the same time??? you can't
aquas
Post by aquas »
hi,
yes it's possible, but you need to check if is not "cloned" in the sequence player, i use the the first three sequences with the cuelist buttons, i've generated lots of cues using only the first 3 sequence positions. In the submasters i use the next sequence positions.
I use it every time, but still i upgrade open the submaster window "blocks" of the dmx output.
cumpr
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
aquas wrote:Hey ppl,
Cumpr
OK I cant say about 3.2.1 as im using a higher beta and Im not gonna downgrade to test this. If you upgrade to 3.2.8 you should find that what you are trying to do will work (I think this is what you want anyway).
So you open up the cue window and run a 'cuelist button' and in the 3d vis or live you can see some output.
Then you open the submasters and the lights all go off. This WILL happen but its probably because you have not pulled the submaster intensity up (this is a virtual slider next to each sub, pull up all of them to be sure but its only going to affect subs that use shutters / intensity channels).
Now before running anything from the subs you should see the sequences from the selected cuelist button running.
Now you can overlay subs on the cuelist button. However you will find that once you start running subs as overlays that if you want to go back to the original cuelist button cycle that you will need to stop any relevant subs from playing and reselect the cuelist button again.
Some of this is covered in my cue / submaster tutorial which you can find here - http://www.freestylersupport.com/fsforu ... f=6&t=1803
or onthe fs wiki here - http://www.freestylersupport.com/wiki/submasters
Im told it makes for some good reading! :ugeek:
aquas
Post by aquas »
thanks dmxlighting, i will test that tonight, because now i'am at work... :( . It could be that, beacuse in previous version did'nt exists the "virtual" shutter to the led fixtures.
Tomorrow i will put some news... ok
cumprimentos(best regards)
