Eurolite TS-5 MK-X Topic is solved
djspc
Eurolite TS-5 MK-X
Hello i received my Eurolite TS-5 MK-X today but i can´t use all the features i edit fixtures in default but nothing anyone tha has this scanner could help me please thank you
Re: Eurolite TS-5 MK-X
you have to be more specific. what features don't work, what did you edit in the fixture? can you upload the fixture. give as much description as possible.djspc wrote:Hello i received my Eurolite TS-5 MK-X today but i can´t use all the features i edit fixtures in default but nothing anyone tha has this scanner could help me please thank you
btw. you dont get help faster by sending PM's about your problem.
- remco_k
- FreeStyler Version: N/A
A manual and/or DMX channel description would also be nice to have. (In fact, without it, helping is quite not possible).
djspc
the features that fail are the gobos keep switching and don´t stop, i have the manual
if you want help i recommend you upload the manual or give us a link for it. also export your fixture file and upload it to the forum as well. otherwise we can't help you
djspc
thank you very much for your time the problem is that i can´t fix the gobo effect the manual is above
Best regards
Sergio
Portugal
http://download.showtechnic.de/?id=4301
Best regards
Sergio
Portugal
- dmxlighting
- FreeStyler Version: beta
Can you upload your attempt at making a profile for this fixture. I will happily have a look and correct any mistakes you may have made.
This way you will learn something from the process rather than me just making you one from scratch.
- dmxlighting
You can export a fixture profile from the fixture creator program. Then just post it to the forum in the normal way
djspc
please if you have some time see what are the mistakes
Best regards
Sergio
Best regards
Sergio
TS-5 2010.pff- (115.68 KiB) Downloaded 97 times
I found the problem, and it is pretty obvious.
in "total channels" you wrote 5 which is correct according to DMX overview.
then in "gobo rot. 1" you have entered 6.. heres your problem. 6 is more than 5
and futhermore the TS-5 dont have the gobo rotation feature, remove the Sechs and the fixture should be allright.
obs: it would be a good idea to implement a foolproof feature (no offence djspc) which control these kind of mistakes.
i tried your fixture with the 3d viewer, but cant see that there should be any problems with the dmx signal.. but try to change your fixture and try again.. let us know how it works
djspc
hello despite of the manual of eurolite ts-5 that says he uses only 5 channels that isn´t correct he uses channel 6 that´s why i have channel 6
i also create macros to stop gobos
http://www.freestylersupport.com/fsforu ... A+eurolite
