Request: Chauvet Q Spot 152 Advanced Mode Fixture Topic is solved
bluegrassbeat
Post by bluegrassbeat »
Hey I was wondering if someone could make a Chauvet Q Spot 152 advanced mode fixture file for me.
Here is the link to the manufacturer's site including manual.
http://www.chauvetlighting.com/q-spot-152.html
I really appreciate it.
Shannon D
Re: Request: Chauvet Q Spot 152 Advanced Mode Fixture
Post by Shannon D »
bluegrassbeat,
Not to be rude or anything, but you really should have a stab at creating the file yourself. Getting your hands around Fixture Creator is a necessity to understand what FS does with the light. If you look at the other fixture files for the Qspot models, you will start to see how the 152 advance should be set up. Trust me, this will help you down the road and it is time well spent learning more about this software. There is info in the wiki, help contents and youtube videos on creating fixtures. The one thing to remember is that if you add the fixture to FS and then you update or edit it in Fixture Creator, you have to delete it from your fixtures in FS and then add it back in.
Once you have created it and still have trouble, come back with specific questions and we will help you.
