I'm sure this is a really stupid question with a really easy answer.
I am running freestyler version 3.2.8 on a windows XP laptop controlling Eurolite PAR64 throught a Velleman VM116.
I have set up a number cues, when I start freesytler and hit the first cue everything is OK when I hit the second cue it looks like the first output is still there.
So if I have a light that is green in the first cue then I want to change it to red in the second cue i get both the green and red leds lit.
how can I get it so this does not happen.
Neil
Problem with Output
nplatt
- FreeStyler Version: 3.1
- LJ_krede.dk
- FreeStyler Version: 3.3.7
Re: Problem with Output
Are you using the cue window and the buttons 1 to 20 to activate your sequences? if it is:
when you have enabled sequence two, are button 1 and 2 red?
* If yes one you have to deactivated the multiselect feature. you can turn that off in Setup --> FreeStyler Setup --> Preferences --> Extra options. remove the checkmark for "Cue Multiselect always enabled"
* if no, go to Setup --> FreeStyler Setup --> Preferences --> Extra options and set a checkmark for "Cue "Go to previous value" always enabled"
/LJ_krede.dk
Aalborg, Denmark
Aalborg, Denmark
nplatt
Kristian
Thanks for your quick reply.
"Cue Multiselect always enabled" was already deselected but when I selected the "Cue "Go to previous value" always enabled" the output on the freestyler now looks like I would expect.
Thanks for your help.
Neil
Neil
