Cue buttons
richard csl
Cue buttons
Post by richard csl »
I love the idea that you can create a look, and save the look to a button, but is there any way the button can have any controls like fade in fade out, run for a timed period then go on to the next button.?
dmxlighting
FreeStyler Version: beta
Re: Cue buttons
Post by dmxlighting »
richard csl wrote:I love the idea that you can create a look, and save the look to a button, but is there any way the button can have any controls like fade in fade out, run for a timed period then go on to the next button.?
Some very good questions / ideas the Richard. The answer is no, not to my knowledge but the fades between cuelist buttons is a brilliant idea.
Its never really occured to me that that would help but I can see the benifits (in my head) already!
The time line idea would be cool to. At the moment you can do this with just the cue page for individual sequences but its not something I have used.
Im not sure if this would be of any help but you could use midi triggers from a keyboard player to start a cuelist button a ta given point, not sure how hard or easy that would prove to be ?
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: Cue buttons
Post by buttza »
I know this was done a while ago but I was just wondering if the fade times between Cue Buttons idea was revisited or added to the FS Software since this forum post?
Thanks. :fs:
