Hi Guys.
I'm starting my own mobile disco, and I'm in need of a fixture for the Eurolite LED PD-3 scanner.
I will try making one myself too, when I get the time for it (a lot of studying is required by my school).
so in the meantime, could someone try to make a fixture or just the basics for a fixture, for this scanner?
It can be found here : http://www.eurolite.de/ (no direct link to the light) then press the "LED products" tab, and scroll down for: "EUROLITE LED PD-3 with 3 mirrors, black" on the list.
Thank you
Rasmus Jakobsen
Fixture for Eurolite LED PD-3 scanner Topic is solved
Re: Fixture for Eurolite LED PD-3 scanner
Hej Rasmus
Vi danskere må hjælpe hinanden
Here is the fixture file. the manual is found on Eurolites website
I haven't tested it as I don't have the fixture. I'm not sure what the ON and OFF function is for, is it for the rotating?
Take a look at the fixture in fixture creator to understand how I did it. You may learn something so you can make your own fixtures when needed
Let me know how it works for you.
and by the way, Welcome to Freestyler
Rasmus4J
Tusind Tak!
og ja det må vi
anywho, as this is an international board, i'd better switch into english
I'll take a look at it and see if I can figure out what you've done etc.
And I have mailed to the company www.lightstore.dk and asked if they could send me an electronic copy of the manual, so that I can check if everythings right, and look into the on off thing you talk about
yet again, Thank you very much!
og ja det må vi
- dmxlighting
- FreeStyler Version: beta
As an ignorant englishman who cant speak my native language that well I would say that all nations are welcome to post in their own tounge but if its possible then post in both english and native. It may increase your chances of help.
