Hey guys
you have four buttons on the BCF2000 to change encoder groups... is it possible to configure these buttons to change encoder groups AND send out MIDI at the same time?
whem I use submasters (SM) (which i do all the time) i use four buttons to change SM pages. i use the first 5 encoder to control the speed of the first 5 lines in the cue window. when I'm changing from SM page 1 to SM page 2 I want the encoders tocontrol the speed of the next 5 lines in the cue windows, which is the same SM 's as in SM page 2....
is that doable?
encoder groups? Topic is solved
- dmxlighting
- FreeStyler Version: beta
Re: encoder groups?
You can set those buttons to do anything you want. (Ignor the printed info on the device)
each fader / encoder / button can only do 1 job though.
I set my encoder group buttons up as 4 overide buttons or submaster pages (cant remeber which now)
Re: encoder groups?
Okay thanks. Then I have to use MIDIOX on the computer to manipulate the MIDI.
