Problem with Freestyler and Icolor4 Topic is solved
alicevanimpe
Hello
I have a big problem , i have buy 2 icolor 4 by Jb Systems. I connect my 2 icolor with the interface Velleman VM116 but when i control the icolor the lamp flash when a mix 2 colors ?
When the intensity is max ,no problem but when the intesity is low or when a mix 2 colors the lamp flash
Please help me
Please help me
Re: Problem with Freestyler and Icolor4
There are some issues when using the Velleman, I dont know if this is one of them.. Do you use a DMX terminator for your DMX daisy chain? if not, this could be the problem causing noise and flickering on the DMX signal
alicevanimpe
Hello
Thanks for your quick response , no dmx terminator on my chain because never problem with my dmx before i buy the icolor (in my chain i have 4 scan, 1 strobo, 1 lyre) and never problem with dmx.
I have try with the controller jb system colormix and no problem , the mix is perfect and when i connect on my velleman the lamp flash
regards
regards
- dmxlighting
- FreeStyler Version: beta
These will be the problem!alicevanimpe wrote:icolor 4 by Jb Systems. I connect my 2 icolor with the interface Velleman VM116 Please help me
Seriously make sure that ALL your kit is talking on pin3+ or ALL Pin2+. If you have kit on both then you will need to cross polarity over. That it unless you have some kit which will auto detect polarity.
Note that pin3+ is the usual standard but more and more is now on pin2+
alicevanimpe
Hello
I used a cable with the 3 pin connected , and in the manual the pin 1 is common , the pin 2 is DMX+ and the pin 3 is DMX-
regards
regards
- dmxlighting
Pin 1 = commonalicevanimpe wrote:Hello
regards
Pin 2 = DMX-
Pin 3 = DMX+
This is how it should be. It should be this way when it comes out from your VM116. So if you use a straight pin for pin cable then yout pin2+ fixture is never going to work. You need to swap pin2 and 3 over. This will probably sort the problem.
alicevanimpe
I think if i have a bad polarity , the color changer doesnt not work.
My color changer work fine (light on , light off, choice of colour) but after use the dimmer the lamp flash a little .
regards
regards
- dmxlighting
Please make a post in your own language as I think you need to understand the problem you have and get an answer you understand as I think you may have miss understood what I am saying. Where are you from ?
alicevanimpe
Bonjour,
Je suis de Belgique
Et j'explique mon probleme ,
J'utilise Freestyler avec l'interface Velleman, hier j'ai acheter 2 Icolor 4 de chez jbsystems ou isolutions, quand ils sont branché sur l'interface velleman , je sais les piloter (allumer, eteindre, changer de couleur,...) mais quand je diminue l'intensité les ampoules se mettent a clignotter legerement un peu comme un strobo et cela fait mal aux yeux.
J'ai tout essayer mais y'a rien a faire, quand je branche les icolors sur une table DMX je n'ai pas ce probleme ..
Pourquoi ?
Je suis de Belgique
Pourquoi ?
- remco_k
- FreeStyler Version: N/A
There's 1 word I understand: probleme
For the rest, someone else should jump in now....
- dmxlighting
Well Im from ignorant england and I still understand more that that!remco_k wrote:There's 1 word I understand: probleme
me to: Freestyler and DMXdmxlighting wrote: Well Im from ignorant england and I still understand more that that!
romano60
J'ai un problème plus ou moins similaire, j'ai 5 changeurs de couleurs macmach et lorsque j'utilise les couleurs ou les gobos, les 5 changeurs réagissent de façon différente et lorsque je veux revenir à tout en blanc les changeurs restent décalés. J'ai déjà essayé de mettre un bouchon DMX mais ça ne change rien.
Quelqu'un peut m'aider???
I have a similary problem, i've got 5 color changer macmah and when i use colors or gobo, the 5 changer doesn't work at same and when i want go back to white, changer doesn't go back.
I already try to put a terminator but that doesn't change anything.
Somedy can help???
Somedy can help???
- Kings
- Commited FS Forum helper
Having just bought an Icolour 4 and using a velleman DMX unit I can confirm that any colour (or blend of colours) will flicker if not at full intesity.
Is this the problem as I agree it is a bit anoying?
Does anyone else see this behavious with their Icolour4 when using another DMX output device?
