Time trigger Sequence start?
Starcruiser
FreeStyler Version: 3.2.8
I Use FreeStyler for: Church
Post by Starcruiser »
Hi, I'm a newbie here and have a question - How do you Time trigger the start of a Sequence in a Cue-list?
I have tried to enter a start-time in the "Scheduler time" field, but when I trigger the Cue with the Cuelist button, all sequences start at once...
What I am trying to achieve is to program songs into Cue's and for instance have a sequence for "Chorus" Then I would like to start that sequence e.g. 1:20 into the song.
Any help is appritiated, and thank you for sharing your knowledge!
Best Regards,
Magnus
FreeStyler Version: 3.3.7
Re: Time trigger Sequence start?
Post by LJ_krede.dk »
you can't use cuelist buttons for this purpose. as you allready find out the button will start all sequences at the same time.
when you have made your cuelist wit sequences and times you save it. when you have your cues for each song you select the desired cue in the fast cue switcher (the drop down menu top left in the cue window). go to cue options (the cog wheel next to the fast cue switcher) and choose enable timecode--> elapsed time. now you have a "start timer" button un the cue window. hit it and the cue will play.
/LJ_krede.dk
Aalborg, Denmark
Starcruiser
Aha, I see!
I've tried and it worked, however only ONE sequence at a time was "playing". Is it possible to have several sequences running at the same time with Time triggering?
/M
