URGENT: fog machine fixture problem Topic is solved
fisch
Post by fisch »
Hi all,
I'm trying to map an Irradiant VF-1200. It's one channel and though it should be easy i cant get it to work. I've set the dipswitch to channel 1, entered 1 channel into fixture creator, fog level min = 0, fog level max = 255, and left fan things blank. It's warmed up and ready but when in freestyler nothing happens. Its on channel 1 and my Enttech Opun Usb should be working.
Any suggestions? I need to fix this tonight!
fisch
Re: URGENT: fog machine fixture problem
Post by fisch »
nevermind problem solved. Sorry to crowd the forum
FreeStyler Version: N/A
Post by remco_k »
Since you've spammed the forum with your question :mrgreen: , and made a whole topic for it, there is plenty of space left below me to type what you did wrong.
Let me guess: you just thought the fogger was set to channel 1, but it was'nt. :?:
