3d inverted?
- Just started using FS
- FreeStyler Version: 2.96f
3d inverted?
why my scans are moving inversely than he 3d view? and when I invert the pan or the tilt, it reverse it too on the 3d, so I cannot trust the 3d to make my scenes...
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: 3d inverted?
There is an option in the 3d easy view to invert pan tilt.
Where all the fixtures and objects are listed next to each fixture is a invert pan and invert tilt option. try those to correct your problem.
Re: 3d inverted?
I search to find a pan/tilt inverter in the 3d view, but I didn't see it, where is it?
I think this will solve my problem, thank you
Re: 3d inverted?
it's ok I found it
it works now!
it works now!
