Error message using shape
Disscussions on possible bugs in the current BETA.
YOU MUST FILE A BUG REPORT HERE before discussing possible bugs.
The Idea of this is :
1. Informing others of confirmed BUGS and
2. Giving other members the opportunity to confirm your possible bugs
dustin
Post by dustin »
I get a popup window with the message "Subscript out of range" when using and changing shapes at the p/t window. After click on "OK" the window will close and the shapes could be used and worked fine.
I tested it with Freestyler 3.2.7 and 3.2.8, also on one system with Windows XP SP2 and on one system with Windows 7 Ultimate 64bit. It is the same on both systems.
Return to “Latest Beta Bugs”
