Error message using shape Topic is solved
dustin
Post by dustin »
Since using Freestyler I get a popup window with the message "Subscript out of range" when using and changing shapes at the p/t window. After click on "OK" the window will close and the shapes could be used and worked fine.
I searched here at the forum, but found nothing that exactly match my problem.
I have this on my both systems. One works with Windows XP SP2, the other with Windows 7 Ultimate 64bit.
Re: Error message using shape
Post by LJ_krede.dk »
dustin wrote:Since using Freestyler I get a popup window with the message "Subscript out of range" when using and changing shapes at the p/t window. After click on "OK" the window will close and the shapes could be used and worked fine.
I just tried it out myself and I have the exact same issue. can you send a bug report to Raph,,, i'm two seconds from going to a meeting
dustin
Post by dustin »
I send a bug report regarding this issue.
edit:
onge was a little bit faster then me ... ;)
