Blackout across multiple channels.
Hambone
Band Member
I Use FreeStyler for: Band
Re: Blackout across multiple channels.
Post by Hambone »
This is much like what I was talking about in my fogger thread, about being able to define, through the fixture creator, which channels in the fixture would respond to blackout as well as what the blackout DMX value should be per channel... although I suppose a "Use Macro #X for Blackout" setting for the fixture would be equally effective :)
http://two-for-flinching.com
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
Onge wrote:I was just looking at a fixture that a user has just created and uploaded a Eurolite SCY-6 LED DMX and noticed that because it has six lenses it is impossible to use the blackout button for it. The only way you can black it out is via a macro to set all channels to zero.
So was wondering if this would be a possible idea for a future version of FreeStyler/Fixture Creator, where you could select a macro to be executed when the blackout button is clicked. Obviously this would be on a per fixture basis. So you can either use a channel/value as it is now or a macro.
Again I do not know how much of a program change this would be or even sure if it would be possible.
Its only impossible if there is no master intensity or blackout channel on the fixture. Some of these type of effects do have this option in their on-board personality. For those fixtures that don't, this is a great idea. As you say though it could be a programming headache.
Return to “Ideas and Remarks”
