[Fixed in 3.1.1] Strange behavior of submasters
cyberb0b
Commited FS Forum helper
Post by cyberb0b »
Is this strange behavior or as designed;
- When i use colors with a fixture, in a submaster and use the % at the right of it, Lets say, turn it to 30%, and i tray the application with the _ button in the upper right corner, the % value goes to 100%, when you untray the application, it wil go back to its original state of 30%.
- When i use a submaster cue for a fixure, for example pan/tilt from moving heads, and in the cue window, place the chasespeed to 10% and run the next submaster cue sequence.. It goes back to 100% chase speed in the cue window..
- And I am using a new touchscreen T230H. (widescreen 1920x1080). and i can't get the touchscreen 1 to fit to my screen corectly. Its to large in length. But i have room to spare on the right.
dmxlighting
FreeStyler Version: beta
Re: Strange behavior of submasters while using application
Post by dmxlighting »
Odd. Has anyone reported this to Raph ?
cyberb0b
Post by cyberb0b »
I did.. :p
