Bugg tracker
cyberb0b
Commited FS Forum helper
Bugg tracker
Post by cyberb0b »
Is there a bugg-tracker somewhere?
So i know which bugs have been reported.
I have found enoug, but i guessing that more people report them.
dmxlighting
FreeStyler Version: beta
Re: Bugg tracker
Post by dmxlighting »
Hi Bob
No theres not. Most people report a bug to Raph and then post about it.
It has been discovered that what some people think is a bug is acually not and its sometimes a misunderstanding of how something works or should be done.
Perhaps you want to post a list of all the bugs you have found with how to reproduce the bug. Also let us know what your full hadrware spec is and what FS version you are using.
Re: Bugg tracker
Post by LJ_krede.dk »
In your profile it say you are using version 3.2.1. try to update to 3.28 and see if you have the same issues/bugs. if you can, send bug reports to raph.
cyberb0b
Re: Bugg tracker
Post by cyberb0b »
I already have upgraded to the latest version, only not my profile but are stil there.. so :) and i bought a touchscreen last week. so i find more and more things :P
What i define as bug, is more as wrong behafure.. and i know its not a build in feature :P
Re: Bugg tracker
I do want to implement a bug tracker its just wether Raph has the time to deal with it or not
FreeStyler Version: N/A
Re: Bugg tracker
Post by remco_k »
DJ Support wrote:I do want to implement a bug tracker its just wether Raph has the time to deal with it or not
It might even help him having an overview of whats to be fixed.
It will be his "todo" list then. But its up to him for wanting to maintain the contents.
Re: Bugg tracker
I'll speak to him about it...
