american dj megabar Topic is solved
Gynther
american dj megabar
Post by Gynther »
hi guys.
i'm in a need for americna dj megabar 7 and 11 channel fixture.
i cant create them because i don't know how to :oops: .
can someone do the fixtures for me.
i know the megabar can be divided in to 3 blocks. Am i right if i assume that the 11 channel one can do that?
sorry my english is not good.
Gynther
dmxlighting
FreeStyler Version: beta
Re: american dj megabar
Post by dmxlighting »
I know that this is a request area but I gonna ask you to look at Onge's tutorial on how to make a fixture profile. Its been recently uploaded and its really good so please have a look at that first and the if / when you still cant do it the perhaps you will get lucky and some will make it for you.
look here - http://www.freestylersupport.com/fsforu ... f=5&t=1904
Gynther
Post by Gynther »
its not the same for a no epirenced guy like me.
i did assing the channels and allmoast all that my mind sayed to fill in that fixture but it didnt work...
tryed in "3d" and there didnt happen anything.
in freestyler i can see the coulour is changeing but i can figure it out.
progress.. i accidentally selected in 3d american dj meg bar pro and it satrted to work.. its a miracle(stroeb dimmer and fist 3 channels[red,green,blue] worked).
one problem is though. i cant see does it work in 3 separate block cause i assume that 3d is not abel/not programmeed to show me that. can anyone confirem that i'm in right direction and i'm not just assumeing it all wrong here?
Post by LJ_krede.dk »
Onge wrote:I am not familiar with this fixture but if it is like a lot of LED bars, then the fixture has to get broken down into lots of parts.
For example you could have a control fixture and then an RGB fixture. So you would patch a control fixture and then patch the number of RGB elements for the bar.
So for example you have a LED Bar which has the following channels
1-Pattern select
2-Master Dimmer
3-Strobe
4-Red1
5-Green1
6-Blue1
7-Red2
8-Green2
9-Blue2
etc.etc.
You would create a fixture that used channels 1-3 (fixture1) and then create another that would be for channels 4-6 (fixture2)
Now if you LED bar had eight RGB elements then you would patch 1xfixture1 and 8xfixture2 then repeat for every real fixture you have.
i made fixture files for the Eurolite LED bar 324/10 this way. mayby you can get some ideas by looking at them.
Gynther
Post by Gynther »
thank you so much;)
i´ll try it out soon.
