Hi forum users,
I got my new DMX4all DMX dongle: http://www.dmx4all.de//DMX4ALL-PC-Inter ... ::254.html
I am trying to use this interface whit feeestyler.
Opend freestyler, set the new interface but windows tells me the program had stopped working.
I opend freestyler for the second time and i got the same problem.
Disconnected the usb dongle and started freestyler, after a while i got an error that the dongle could not be found.
I have installed the drivers and the pc recognized the dongle.
Operation system: windows 7
Hope you can help me.
Greetings Erik.
Freestyler dies whit DMX4all Topic is solved
Lithium
Re: Freestyler dies whit DMX4all
Thanks for your fast anwser.
Sorry i forgot, 64bit. In the weekend i will install windows xp32bit and hope it will work there
Thanks for your help, i will let you know if it works.
