Output thread? Topic is solved
wings1221
Output thread?
Post by wings1221 »
I'm using an Enttec USB Pro and 4 Accuspot 575's with freestyler. I choose the proper interface (Enttec USB Pro obviously), and when I click close it's like Freestyler can't connect to the fixtures. I always get a message along the lines of "No output thread created".
I'm new to this program.. could someone tell me what that means and what I'm doing wrong?
Re: Output thread?
Post by LJ_krede.dk »
"Error creating output thread" error comes when freestyler cant find the usb interface..
When you have chosen the right interface in "freestyler setup" (as you already did) a new drop down menu will appear. Here you have to select which (virtual) comport your interface is connected to. If you don't know which comport it is, open up the device manager on your computer and find the Enttec USB DMX PRO interface. the comport number should be parenthesis besides the name.
select the right comport number in freestyler setup, press save and restart freestyler. then it should work (if the proper drivers for enttec pro is installed, as Onge said)
Kings
Commited FS Forum helper
Re: Output thread?
Post by Kings »
Had the same problem so have a look at this thread:
http://www.freestylersupport.com/fsforu ... 7023#p7023
Let us know how you go!
