Elation 300E Topic is solved
remdim
Elation 300E
Post by remdim »
Anyone worked/working on this profile? Attached is a mostly written file; however dumping it into 3d View is proving difficult. Any thoughts/advice/help would be greatly appreciated.
Thank in advance!
300e.pff
(67.35 KiB) Downloaded 33 times
FreeStyler Version: N/A
Re: Elation 300E
Post by remco_k »
If the problem is in 3d easy view, then you should not be looking in the fixture file that is made for FreeStyler, but in the Scanlibrary for 3d easyview.
